Hi, guys. I have read this site for years now and slowly I've been buying parts and getting all the componets for a year. I've done a lot of research and read other people's posts.
I unfurtunately have found out that things are that NOT easy to do.
I'm using Rancho shocks, OME 912 Coils Springs and 2 1/2 spacers as bigpoppax2 has done.
The bolt for Driver side upper link needs to be removed since I will not drop low enough to move the coil spring.
This was hard to do since I coil spring will not let the bolt come out. I had to get a coil spring compressor to remove it. Make your life easier and get a coil spring compressor.
I was finally able to remove it and drop it enough to put the 2 1/2 spacer and 912 coil spring. My huge problem is that I can NOT get the UPPER LINK bolt to line up properly to screw it back in.
Any ideas?!
Any ideas?!
