So I'm probably gonna go pick up some junkyard 16" snowflakes this week. They say they are in fair condition. But I think it would be neat to refinish them and bring back some shine.
So how do you do it? Grit blast? Emery cloth? Clear coat? Wax? Polishing compound?
I know I've seen some guys on here bring some beat up rims back to near showroom condition. Give me some hints. Pleaaasse.
I am hoping to refinish my rims this summer. Planning on going black or gunmetal on the inside and polishing the flat surfaces with a ton of clear coat over them.
In for advice, pics, and discussion.
I didn't have the patience for polishing. I had mine sand blasted and painted them with wheel paint. The texture gave a cool texture to the paint.
I'd like to keep the milled look, so I'm thinking die grinder with scotch brite pad.
What do you guys use to preserve the finish, wax? clearcoat?
Quezzy said:
You dont know how to use a high speed drill or cut off tool?
No, my mommy won't let me.
I used aircraft paint remover and removed the clear coat first. That will tell you what you need to do next. Mine looked super bad until I took the clearcoat off. Post some pics, before after and durring.
He didn't say he didn't know how.
He said he didn't have the patience for it.
I did it on dirtbike forks, but the same principle applies. Bike is an 83, troop is an 88, so there close in age. Clearcoat was peeling off, so I just took a red scotchbright pad. I cleaned off the clear and cleaned up the metal. hit it with some polish and they look real good.
I redid some turbine designs by putting the whole wheel into my brake lathe and turning it while I held a high speed grinder to the surface with a 60# flap wheel on it.
They cleaned up nicely and then I polyester coated the polished surfaces and they're still looking good, seven years later.
