For those of you reading with Troopers, last weekend Adam and I installed 2.5" spring spacers on top of OME919 springs under my 94 Trooper with just a socket wrench, two jackstands and a floor jack. We didn't even remove the tires.
Step one: Park the truck on level pavement, and block the front wheels with chocks
Step two: Jack up the rear of the truck under the differential with the jack as high as it will go.
Step three: carefully lower the truck until the frame is sitting on the jackstands. Try to keep the truck as high as you can in this step.
Step four: remove the nuts from the lower shock mounts, and pull the shocks off of the lower studs. Let them dangle.
Step five: (optional depending on total lift) unbolt the brake line Tee fitting from the bracket on the rear axle and carefully bend the hard lines so that the Tee is aprox 2.5" above where it was before. When installing just lift springs, this step isn't needed. When I went back to install the spacers, I had to do this step.
Step six: lower the jack until the springs fall out. Keep an eye on the rubber brake line, especially if you didn't disconnect the Tee from the bracket.
Step seven: Install springs/spacers
Step eight: Jack axle back up.
Step nine: Reconnect shocks
Step ten: jack axle up enough so that the jackstands can be removed, and remove jack stands.
Step eleven: lower truck.
-Tad
