I had to replace the combo (dimmer) switch in my 92 Rodeo so I took some pics so others can see how it's done.
A new switch costs anywhere from 130 to 200 dollars but I found one at the local Pick A Part for 25 bucks.
I'm not much of a mechanic and some of the steps are just common sense but I figured I would post them anyways for other newbies like myself.
Part One (replacement)
(click on the pics for a larger image
First step is to remove the steering wheel, to do this you need to remove the horn cover.
To do this ya need to remove just one screw from the back of the steering wheel (circled in red)
The cover is held on by the screw and a couple of clips (circled in red). As you're sitting in front of the wheel pull the bottom of the cover out a bit and lift it straight up. Then disconnect the wire for the horn (circled in blue)
Pic showing the horn removed. Circled in blue is where the horn wire hooks too.
Next remove the nut from the end of the steering column. After the nut is removed it's a good idea to put a couple of witness marks on the steering wheel and column so you can get it back on in the right position.
Then use a puller to remove the wheel.
Next ya need to remove the column covers. To do this remove the 5 screws from the bottom cover and pull the covers apart.
3 of them are machine screws and two are a course thread screws. Match the colors in the pic below with the pic above to get them in the right locations.
I couldn't get the top cover all the way off without first removing the cover above it with the light switches and wiper switches in it.
This is held in place by two screws on the bottom of the cover. One on the left side
and another on the right.
Then disconnect the electrical for the lights and the wipers. With that out of the way the top column cover will lift out.
Pic showing the bad combo switch. To remove it just remove the two screws circled in red.
To get to the wire plugs one more cover needs to be removed. This one comes off by removing the 4 screws along the bottom and pulling straight out.
Trace the wires from the combo switch and unplug them. There are two plug up inside behind the dash (sorry couldn't get pics of them). The wires are secured to the steering column in a couple of places with zip ties so these will need to be cut and replaced. Once ya them unplugged pull the wires out and remove the switch.
The small plug is for the cruise control and the large plug for the blinkers and lights.
Install the new switch in reverse order and you should be good to go. One thing to pay attention to is the two stubs (circled in red) on the center ring of the switch. They need to line up with the holes in the back of the steering wheel. This ring is what turns your blinkers off when ya straighten out from a turn so ya want to make sure they are in the correct position.
Part Two below
Part Two below
