Repair Manuel TOD System [30 pin GCU] for UBS69GW series
1 reading
29 views 4 replies 3 participants last post by  mikeneumann007
#1 ·
hi
need a document / Manuel to check my TOD system. Many new parts bought and installed - still no joy in clearing the 'check' system light.
thank you
#3 ·
hi
i am not sure - if it part of the GW69 series then yes.
4x4 Engages - both low and High ... TOD system just flashes... traction control display [green bits] front wheels move back and forth showing % power transferred ... the TOD check light flashed - i am not sure if that is as it should be.
i fitted free wheel hubs to help with fault finding. with the front diff locked all works as it should ... TOD check light flashes.
When disengaging and unlocking the front hubs the transfer case still turns the front prop... [it thinks it is still in 4x4 i think] and check light flashes.
i suspect there is a return signal not functioning as it should.
ABS wheel speed sensors all work as they should.
