Removing center console to get at Power/Winter button
5.9K views 6 replies 5 participants last post by  duel007
#1 ·
Hi everybody,
Just have some more questions for my current project. I need to tap the switch backlight power wires off of the Power/Winter Drive button for the fog light switch I'm putting in the empty space. How do I remove the switch?
Or just remove the whole center console?
Thanks!
#6 ·
duel007 said:
chikoroll said:
why not tap into the clock?
I suppose I could, but that would be a pretty long run, and seeing as the wires for the Power/Winter button are right there..
Maybe you guys are confused on the placement, I'm putting a fog light switch in the empty spot to the right of the Power/Winter button.
TAKE A VERY SMALL KNIFE BLADE , AND INSERT IT AROUND THE EDGE OF THE SW AND PRY IT UP GENTLY ONE END AND THEN THE OTHER , IT IS HELD IN WITH SPRING CLIPS MADE ON TO THE BODY OF THE SW, IT IS JUST PRESSED INTO THE HOLE ,JERRY
