I've been putting off some work on the Trooper so It was time to get started. Instead of several different threads or making the original Tow Boat thread 20 miles long I decided to start a new build thread. 1st a couple of posed shots on a camping float trip a couple of weeks ago. Just so we remember why we do this stuff.
I started on the rear axle because I just picked up a much needed rear sway bar. I have had a set of used Calmini HD sway bars since I got my truck. The front one is on the truck and the rear one won't work well with the OME springs I have. So I picked up an ADDCO rear sway bar for the 1st gen.
Addco on top. Calmini on bottom.
Calmini clamps to the leaf springs and the clamps won't line up and the U bolts are now much too short. This is Calmini bar laying on the spring where it would clamp.
The Addco bar end link goes to a plate that mounts on the bottom of the spring plate. And the fact that my OME springs are thicker. The end link is off by about an inch. Now add 2" of lift and that becomes 3" off on one end or the other of the sway bar. Frame mount or end link.
I'll either have to make the end links longer or space down the frame brackets. I actually have a kit that does that in my other truck which made me think that dropping the bracket was the way to go. The end links are pretty long already.
The sway bar kit comes with these cool U bolts that go in the frame.
I found some 3" channel at the junk yard down the road. It still has wood attached to it.
The size was right and It cleaned up fine. So here are my drop brackets.
I ended up turning them open side out because they just worked out better that way.
Much better angle on the sway bar arm here.
Than here.
End link bolted up.
That takes care of the sway bar. Had to take it back apart for paint and it's on the 2nd coat now. I haven't checked the exhaust now that this is together. Maybe it will go right over the sway bar since I dropped it.
Remember 2+ years ago?
Well 2 salty winters later here in the Mid Atlantic.
I knew my E-brake cables had frozen up. it seems so had the E brake part of the caliper.
The calipers also were not floating at all. The drivers side was stuck pretty well on the pin. It took some serious prying to get this caliper this far. Hasn't been that long since I last lubed them! 22k from a set of rebuilt calipers.
The rotors had worn as well.
So after a trip to the machine shop my Powerstop rotors are now nice and smooth again.
Still waiting on some brake parts. and then they will go back together along with new E brake cables. I'm going to change the rear diff oil, lube the driveshaft, and work my way to the transmission and transfer changing oils and then the front axle. Much more after that as I get to things.
Than here.
End link bolted up.
