FIRST WHICH ENG DO YOU HAVE , 2WD ANYWAY MOST OF THOSE HAD 4.10 WITH THE 2.3 A 2.6 ENG COULD HAVE HAD 4.10 ,4.30 OR 4.55 DEPENDING ON THE TIRE SIZE THERE ARE NO GEARS TALLER THAN THE 4.10 THAT WILL FIT NO MATTER WHICH ENG YOURS CAME WITHebgbz said:I understand that a '92 2wd Amigo has a 4:55 gear in the rear end.
Is that the case and if so...where would one go to get a higher gear...say like a 3:73
This little Amigo winds up way too fast AND tight!
That requires a good balance job on the engine internals and a different camshaft. 2.3/2.6 are cammed for moderate rpms. They don't make much power above 3.5k RPM. They could also benefit from some serious balancing work.ebgbz said:Hey squatch...
You are exactly right!
However, what I wamt to do is make a "a light weight Amigo with a high RPM motor."
I just sent you a PM.ga trooper said:What is the info on the turbo impulse in Tampa?? Might need to go to sunny florida!!
They could, but there's only so much you can do on an L4 with no balance shaft.squatch said:They could also benefit from some serious balancing work.
