amigozilla said:
I don't want to say "no you're wrong", I only know what I've seen with my '98 with the 2.2. I'm pretty sure the motor is GM, based on the "GM" cast into the side of the block. According to the owners manual the trans used in the 2wd models is a Borg Warner gear box not sure about the bell housing. The 4wd models use a MUA5 trans with an integral bell housing.
As for what bolts is direct bolt-in, I'm still trying to sort that out. Good luck though!
OK , THE TRANS IS A BORG WARNER 5 SPD , THE ENG IS A GM SOURCED ENG FROM AUSTRALIA, USED BY DAIEWOO, MANUFACTURED BY HOLDEN, AND WAS BUILT IN ABOUT 3 DIFF SIZES , NONE WORTH A DAM, IT DOES HAVE A REMOVE ABLE BELL HOUSING , BUT ONLY FOR A COUPLE OF YEARS , AND THEN ISUZU WENT TO THE MUA WHICH AS DENNIS MENTIONED DOES NOT HAVE A REMOVE ABLE BELL HOUSING EVEN IN THE 4CYL TRUCKS , THE BORG .WAS JUST TOO TROUBLE SOME, AND NEVER SHIFTED AS GOOD OR SMOOTH AS THE MUA.
BUT YOU NEED AN ENG, THERE IS REALLY NOTHING OUT THERE THAT WILL BOLT RIGHT UP WITH OUT A LOT OF WORK, AND A TON OF WIRING
THE SIMPLEST SOLUTION WOULD BE TO FIND A 2.6 GAS ENG FROM 93-95 FROMA 2WD RODEO , THEY ALL SO USED THE SAME BORG WARNER TRANS , YOU WILL NEED TO GET THE CORRECT BELL HOUSING , WHICH WILL FIT YOUR TRANS, USE THE ENTIRE 2.6 CLUTCH AND STARTER FLYWHEEL SETUP.
CONVERT THE ENG OVER TO A 2.3 CARB SETUP AND YOU WARE READY TO GO, BUT THE FUN BEGINS WHEN YOU START TO ATTACH THE A.C SYSTEM AND THE PWR STEERING SETUP.
OR TRY AND LOCATE A 98 OR LATER RODEO AND PULL THE ENTIRE ENG AND TRANS AND THE WIRING FORM THE BODY AND THE ENG COMPART MENT AND DOA COMPLETE SWAP, IT WILL BE ABOUT 90 % BOLT IN AND YOU WILL HAVE A MUCH NICER VEH.
