Hello. No offense, but your message might be a little too general. Is this a hissing noise or a whinning noise? Some things to check to start off: squeaky belts (particularly if your motor got wet), vacuum leaks, foreign object caught up in moving parts. Once I found a very small stick caught up in an electric fan that created a horrible noise. If you did only light wheelin' it's probably something easy. Good luck.
-Kevin
-Kevin
