1 - 7 of 7 Posts
· Registered
I know you have to jumper the two connections, but I can't find the connector. Is it pluged in to another plug on the harness? Is it just hanging out there by itself. Is it the 3 wire plug or the 12 wire plug on a V6?
Thanks for any help,
Rusty
· Registered
Ok. Under your center console you will find your computer. There will be one plug that is connected to nothing. It is a black plug. Looking at it there is two wires next to each other. Use a paper clip, piece of wire. Connect these two wires. Turn the ignition on, DO NOT start the truck. Just move to the ON postion. The check engine light will flash. The three will be 12 ( Flash *pause* flash flash)
Then it will flash the codes 3 times a piece. The last code if I remember right is a 55.
I believe it is the same. I think. Let me know if it isn't I can figure it out. Just have to go to a junkyard and find a 90 with a 4 cly.
· Registered
I'll try it but I moved my Comp. box from center consol up to behiend glove box. I've had water up to door handles with 3" lift and 33" tires and now I run without the doors! So I moved it as high as I could. 8)
· Registered
Humm, it is the only plug near the ECU. Black and pluged into nothing. It is in the same harness as the ECU wiring so you should be able to find it pretty easy.
· Registered
Joe Isuzu said:
Yea post it, but I have a 2.6 - 4 banger
Hi,
Your's "used" to be in your center console as well. Instead of the black connector, you have a male and female spade connector. They should be coming out of a wire harness near the plugs that go into the computer.
Adam
1 - 7 of 7 Posts
