1 - 4 of 4 Posts
I highly recommend the GREASABLE Prothane 1" Style "A" bracket (19-1158) over the NON GREASABLE 26mm Style "B" bracket (19-1142). I've had both and the Style A bracket has much shorter mounting "legs". The Style B bracket sticks out beyond the end of the frame.
I have a Style B bracket on Trooper #1 and Style A bracket on Trooper #2. I can take pictures if you like.
Also, get go the hardware store and buy new 8mm x 1.25 nuts and washers. The factory ones have too small of an outer diameter to hold the new brackets securely.
The numbers you posted are NON GREASABLE. I recommend the following GREASABLE bushings:
Prothane 1" Style A: 19-1158
Prothane 19mm Style A: 19-1162
I also used the "THIN" bump stop instead of the regular button you posted.
Prothane 3/8" x 2" Thin Button: 19-1319
thanks... i used the following..
1 - 4 of 4 Posts
