1 - 20 of 28 Posts
It all started with a Craigslist ad, a 95 Trooper with a 5spd and a shifting problem for $800. I was also looking at another ad for a 96 with what sounded like timing tensioner rattle. The guy with the 96 never got back to me. I got a ride up to look at this truck about 50 miles from home, and found it to be in fairly good running shape, but with a pushed in bumper, stuck in 2nd gear and leaking power steering fluid from the pressure hose. No amount of working the shifter back and forth would get it even into neutral. I figured the shifter was just worn and slipped between gears and I'd be able to fix it fairly quick. I offered the seller $600, he said he'd take $625. That bought me this.
I hopped in and took off in 2nd, headed for home with darkness closing in. After going a few miles I decided to take a stab at getting the shifter out and fixed in a grocery store parking lot. The bolts were being stubborn, hard to reach, and about that time a drunk driver crashed into a pole just outside the lot. With expired out of state plates I decided to just run it and got back on the road.
Most of the trip went smooth other than having to wrap out the RPMs in 2nd then coast just to come close to highway speeds. It made the trip tho, without any other problems.
The next couple days I read and researched and tried to figure out what might be wrong inside the tranny to cause it to be stuck in one gear. I had visions of bent or broken shift forks, seized bearings, basically nightmare tranny killers, but my gut said it has just gotten the shifter out of place. Finally I got out the 4 bolts holding the remote shifter on and found the right shift rail slid into 2nd. I popped that back into the neutral position, and started it up. Sure enough it was in neutral. I put the shifter back in, and the gears seemed to shift fine. I buttoned it back up and drove around then down to the DMV for title transfer. It has been my daily driver ever since.
I had bought a spare tire cover about 6 years earlier thinking I'd repaint it to match my brown 86. I never got it done, but it turned out to be a color match.
Nice! Check with Jerry for a shifter bushing, they wear out, the slop might have got yours bound up. Oh, and if your PS hard line is leaking, it is tricky to find the right one, all the parts stores show an incorrect line. Might be worth asking Jerry about that too.
I started with the beginning of the story, which was actually more than a year ago. Both of those issues are long gone and fixed. I got the bushing for the end of the shifter from Jerry and the power steering pressure line from a parts store. I didn't have much trouble finding the right one, but then I usually tell the store a part number after doing my own research instead of relying on their idea of what fits.
The shifter issue has come back once, sticking into 3rd gear this time. I'm thinking of swapping the remote shifter pod, but it's a fluke thing so not a big priority yet.
For the first year I mostly just drove it. Replaced the shoved in bumper, broke the bug guard slamming the hood too hard once, and generally just collected parts.
It now has a factory rubber rear mat, cargo cover, and more recently a Dakar badge, compass, map lights, lighted sun visor, and driver side grab handles.
Besides the "show" parts, I've also got Aisin manual hubs ready to put on. I have some rough idle and slow start issues so I've some multech2 injectors ready to go on when I finish collecting up the parts to pull the intake. The plan is to replace the timing belt, water pump, tensioner, valve cover gaskets, one cracked valve cover, cam plugs, water pipe o rings, and maybe swap to aluminum timing covers.
Also in the queue is a pair of grand Cherokee springs to lift the rear. Thanks to DutchBro for that Christmas present.
The radiator had developed small leak from a crack near the upper hose connection last month. I put a band aid on that with some very rough sand paper and JB weld. So far that has held great but the new rad is about to get ordered.
Coming soon will hopefully be a LSD rear, and of course actually turning bolts and putting some of these parts on.
I found a cargo cover and the large factory floor mat for the rear on trips to the junk yard.
I caught a deal on the sway bar end links through rockauto, you can see the difference between stock and the new greasable replacements from MOOG. I also replaced the sway bar bushings with greasable poly from energy suspension. The rubber originals were spongy from getting soaked with power steering fluid and just age. The end links went on at the same time as a pair of KYB gas-a-just shocks. The factory originals had long ago ceased to absorb any shock. Overall the on road handling was vastly improved, and the ride is smoother too.
When I got it, the bumper had been hit and shoved up and back. I got a replacement from the junk yard and mostly for the grill, body pieces, and headlights pulled back into place. The Dakar badge was another junkyard find.
I found an Acura SLX at the junk yard and pulled the compass/altimeter, the map lights and sunroof control, and the metal bracket that holds both in place. Here is the bracket installed and the cuts into the head liner done.
And here are both installed. For the cut out, on the map lights just cut to match the hole in the metal bracket where the lights clip in. Doesn't have to be perfect, just don't go too far out or the map light won't cover over it.
I wired power to the lights from the dome light, the white wire is hot. I also installed the drivers side lighted mirror visor, wired to the same for power.
With all these things, always get the connector and cut as much of the wiring leading to it that you can get. It just works better if you have as much factory harness and connectors as you can get.
During this process I also installed the grab handles above the driver door and on the windshield pillar. You have to cut a square hole in the trim but it's fairly easy to see where. I used a dremel with a rotary cutter bit, just take care not to go too big or it will show.
I haven't locked myself in the back yet, but I wanted to avoid that problem so I picked up the parts to add back in the rear door inside handle. 92-93 Troopers have the handle, but by 94 they decided it was too dangerous for people hauling kids in the back and removed it. You need the inside handle, the latch mechanism, and the rod that connects the two. There are clips that hold the rod in place but zip ties looped though worked better than reusing the clips.
In the first pic you can just see the white square where the inner door handle will screw to. I didn't grab the screw retainer from the donor, but these for license plates fit, just barely and with much force.
This is the cut out needed on the door panel for the handle, notice the outline in the plastic showing about where to cut. Don't go to the line, cut out roughly a rectangle leaving a little less than half an inch before the line.
Finished install and put on the cargo racks too. I got these from a truck with brown interior and painted to almost match Can't say I'd recommend going that route. Try to find a match if possible. They are attached by drilling holes in the door panel and using push lock fasteners from the hardware store.
Thanks for reminding me - I need to keep an eye out for a 92-93 for rear door handle setup. My old 93 RS had one.
I actually picked up an extra handle, rod, and latch. Not sure what it would cost to ship, that rod is kind of long so it would need a bigger box than the other parts
I still have some adjustments to the sheet metal around the grill and headlights but I got the chrome 94 grill installed that I picked up from the last junkyard trip. The parts around it are just slightly off from where the bumper pushed up into them and it made fitting the grill a bit of a challenge. Looks better though.
I also got the CB antenna mount installed and stuck the CB in the blank under the radio. I was hoping to fit a Uniden President Grant radio in there, but that thing is huge. So I gave up the extra tweaked power and side band for a Cobra 18WX ST II. It fits perfectly and the metal brackets from the storage box that was in that space can be used to secure it. The hole on the brackets furthest in is about 1/2 inch too far back tho, so drill a new hole further out to line it up perfectly with the dash trim. Picture of that installed to come, or I'll figure out where to mount the Uniden.
I also have a pic of the coming attraction:
Needs cleaned and paint, then a free couple hours to install.
Very Nice. When you get a chance post a picture up of your cb!
I still haven't pulled the CB back out to drill the holes further out to get it sitting out just right in the dash.
Yep, that's what I did.
Right now there is a gap in front of it. It also sits too far back and I can't see the channel or the meter while driving.
Ah I see what youre saying. Surely youll figure it out lol. I have a cobra 25ltx classic mounted on the passenger side of my radio bin
I swapped the map light bulbs for LED. I found these on amazon that are flat instead of multisided:
Cutequeen 4PCS LED Car Lights Bulb White T10 3528 8-SMD 194 168 (pack of 4) https://www.amazon.com/dp/B00BGJBMC4/re ... wvb12HDWBX
I haven't tested at night yet, but I bet you can tell which bulb is which.
Finally managed to get the limited slip third member cleaned up and installed.
First the new part got the rust cleared off and a coat of paint.
Then I got the truck up on jack stands and drained the diff, finding this on the magnetic drain plug:
Unbolted everything and dropped the diff (on to a cardboard box to break the fall, heavy sucker) and I found this inside:
I cleaned several more chunks out of the axle housing. I'm still not quite sure what failed to let the spider gears start to chip like that but I was already planning to pull the open diff anyway for the replacement so not too worried about it. To finish up I ran a small magnet around inside the housing and extended it as far down the tubes as I could reach. Then I cleaned up the surfaces of the parts to reassemble and coated the mating surfaces with non hardening permatex. Took two of us to lift the third member into place and slide it in.
The final step was a test drive, which had to wait until the next day since it was late.
A few months back I started a project to do all the things I could think of to my engine all at once. It has gotten stalled along the way but I'm getting closer and ready to make a final push to finish it. Here is the modest list of replacements, swaps, upgrades, and maintenance tasks:
Swap cams from a 97 engine
Swap intake rockers and shafts to cut the rattle
Replace a cracked valve cover
New valve cover gaskets
New intake/plenum gaskets
Clean intake and throttle body
Swap upper timing covers to aluminum from a 96-97
New timing belt
New tensioner
New water pump
New coolant pipe O rings
Clean the sludge out from under the intake in the "valley of doom"
Swap injectors and harness connectors to Multec2 (98-02 Isuzu V6)
Clean and service the "new" injectors
I've got a lot of this done, but a lot of reassembly left. I'm starting on the injectors I got from a donor now. I've glued a red tube from a can of injector cleaner into a plastic valve stem cap. A rubber tire valve stem squeezes just over the top of the injector, then the modified cap screws on. I've wired one injector connector to a small 9v power supply to use to pulse the injector open while spraying cleaner through it. I found I needed 4 hands to hold the contraption, spray, and power the injector. I needed a foot switch...
There is a lot to update on this post. Swapped cams, swapped to 98+ multec 2/Delphi style injectors. I'll update more soon.
Only took a year but I finally got the CB mounted further out. I drilled a hole in the metal mount for the storage bin a half inch out from the original hole i had been using. You could get out dead on flush if you wanted but I wanted to be sure I could see the channel readout without leaning down. I'm still going to take this CB out though and replace the bin. I'll put my President Grant hanging off the side of the console.
I also replaced the instrument panel surround. I found one that had the factory anti theft light in it, but was from a manual trans truck so it did not have the auto trans display. Not too common from what I've seen to have factory anti theft with a manual trans. The bit I'm holding in the pic is the cheesy looking alarm LED that was installed with the aftermarket alarm. Just hooked up the wires to the factory LED and it works great.
Nice project! I've done the rear door handle as well for my kids.
I have the compass that I've been waiting to install since I figure I'll have to take the dash out and wire it to the stereo, etc. From what it looks like, you wired it to the lights, correct? Did you have much wiring to do past the rear view mirror? I would like to see more of how to installed the compass.
Thanks!
Matt
1 - 20 of 28 Posts
