Project: Stratotrooper
30K views 64 replies 11 participants last post by  SRN
#1 ·
Introduction:
When I bought my Trooper six and a half years ago, I got it for the primary purpose of getting out to explore the vast backcountry of Utah. In that time I have traveled thousands of miles of dirt with it, never doubting it would get me to my destination and back. I've done some mild modifications, lift, transfer case gears, and a few other odds and ends; but other than that it is completely stock. So when I noticed an odd noise coming from the engine a bit ago I was more sad than anything. At 234,000 miles, only around 50,000 of those being mine, I was hoping that the engine would last a bit longer. But, not knowing its maintenance history before I got it, I suppose I can't be too surprised. I diagnosed the issue as a rod bearing, so not an easy fix. I was looking at the prospect of either rebuilding the motor or getting something new to replace the Trooper as my primary exploration vehicle.
How it was when I bought it.
First trip off-road up American Fork Canyon.
Black Dragon Canyon, 2014
I spent some time thinking about it. The Trooper is nearly 25 years old; but it has been the perfect vehicle for me. It has plenty of power, capability, space, and comfort. And even looking down the barrel at spending around $3,000 to rebuild the motor; there isn't another vehicle out there that matches it for the cost. I'd dreamed of one day replacing the Trooper with a Mercedes Gelandewagen or a Nissan Y62 Patrol; but at this juncture they are a bit out of my price bracket. I could find an 80-series Land Cruiser for around what I'd be willing to spend, but in so many ways they're a downgrade from a Trooper. A 100-series is more in line with the Trooper, but people think they are gold.
At the end of the day, it really was a no brainer for me to dive in on rebuilding the engine. But by committing to that path, I'm also committing to having this vehicle for another five to ten years. That means it cannot be simply rebuilding the engine, this needs to be a comprehensive refresh of the vehicle. I will do this in the following phases:
Phase I: Engine Rebuild
The Isuzu 6V1D engine is a solid motor, particularly when mated to a manual transmission. Making 175hp and 188lb-ft of torque I've never felt that it was lacking. But, if I'm going to rebuild it may as well make some improvements. After reading through some very excellent posts discussing DOHC swaps and using the SOHC single chamber to gain a little bit better airflow and low end power I figured that'd be a pretty good upgrade to pursue. While reading about that setup, I also came across the idea of swapping the stock Multec-1 injectors with Multec-2 injectors from later model 3.2L and 3.5L Isuzu engines. This is supposed to increase efficiency and again, gain a little bit of power. With these small upgrades, I should be getting closer to 200hp and 200lb-ft of torque; not an insignificant increase! All the while, keeping the engine efficient and reliable.
While I have the engine out, I'll also be replacing the AC, power steering pump, alternator, clutch and all the associated wear components so that everything is as fresh and new as possible. I'm also going to be adding a secondary fuse block for all my add on accessories like the fridge and HAM.
Phase II: Exterior
What's the point of having a car drive like new if it doesn't look new? I don't have a lot of rust, but I will be eliminating what I have. With the rust gone, I think the Trooper would look excellent in Toyota Quicksand with black along the lower quarter. I also will be tinting the windows and replacing all the exterior lights with LED's.
Toyota Quicksand paint color
For armor, I'll be building custom front and rear bumpers and modifying some Rocky-Road Outfitter rockrails I've been sitting on for years. Since I rerouted my exhaust last year, I'm also going to be building a new skidplate to protect the tranny and t-case.
I've enjoyed the Scepter can holder I built a few years ago, but I want to make some improvements to it and maybe build one that holds two cans. That way I can carry 10 gallons of extra fuel or five of fuel and five of water. I'm also toying with the idea of getting a 35 gallon Long Range Automotive fuel tank. Group buy anyone?
Finally, new badges. I figure I'll make some new slightly more modern looking "Trooper" and "Isuzu" badges. Because I have access to a vinyl cutter and why not?
Phase III: Interior
All interior lights will be changed to LED. I have a BlueTooth stereo at the moment, but I'm not too happy with it; so I'm going to find a better one. I have a iPad Mini mounted up for GPS duty, but I'll be plugging that directly into the new stereo via a rear USB port and using it more like a full "infotainment" center. I never use my CB anymore, so that's going away and I'll be upgrading my 25-watt HAM with a 50-watt unit. I'll be adding another 12-volt power outlet in the lower part of the dash and a few USB ports in the center console for charging devices.
In the rear I already have two 12-volt outlets on the passenger side, one of which is a dedicated port for my fridge. I'm going to put another outlet and a couple USB ports on the driver's side.
Finally, I'm going to put sound deadening everywhere. Every piece of carpet and panel that can come up will get sound deadening underneath or behind it.
Conclusion:
What's in a name? Everyone calls their Trooper a "Super Trooper", so I couldn't do that. I got to thinking; there was the "Fortress", the "Superfortress" and finally the "Stratofortress" in Boeings line of large strategic bombers. Additionally, the B-52 Stratofortress is the longest serving aircraft in the USAF inventory, and over its long history has gone through many modifications and upgrades to keep it relevant. And now it looks like it will be serving well into the 2050's, 100 years after it first flew.
This project will take time, but I hope to have the vast majority of it completed by next fall. And once complete, much like its namesake, the refreshed Stratotrooper should serve me well for years to come.
#52 ·
Update of sorts. Took the Trooper out on its first real trip since the rebuild two weeks ago to the Swell. We ran Eagle Canyon, Eva Conover, North and South Coal Wash and Devils Racetrack. Everything was running like a champ until I bounced a bit on a ledge on Devils Racetrack. After that, unless I was in 4-Low it'd just sputter until I raced the engine up over 3500 rpm and dump the clutch.
Some basic diagnosis at camp had me thinking it was a bad fuel pump. Trailered it home, did some more tests for fuel pressure and it sure looks to be a pump. So now I'm soaking those tank bolts in anticipation of dropping that! Goodie. And right in the middle of buying a new house and moving; great timing...
#55 ·
blitzen said:
Just wanted to say that I have checked out your project Stratotrooper and stephennielson.com what beautiful scenery you have to take that Stratotrooper in and through!! some day I hope to make it out that way...
Dave
Thanks! Utah is a beautiful state, for sure!
The Trooper has been in a bit of a holding pattern for the last year. Between the medical issues that I had, buying a house, and getting married there hasn't been much time for it. I'm still driving it and taking it into the back country, but my free time of late has been dedicated to home improvement projects.
Soon those will be "done" and I'll be able to get back on finishing up the Trooper!
#57 ·
As I'm sure many of you have been waiting with baited breath for an update on my Trooper, you don't need to wait any longer! Since the last major update, I've recovered from a major injury/illness, bought a house, and got married. So the Trooper has understandably taken a bit of a back seat. That said, it hasn't just been sitting collecting dust. No, it's been out on about a dozen trips of varying lengths since last summer and has performed admirably. Which brings us to today's update.
Phase II:
On a couple of my recent trips I've come close to my fuel limit between the 22 gallons in the tank and the five gallon's out back in the Scepter can holder a friend built for me years ago. A double Scepter can holder was always in the plans of upgrades I wanted in this project. Back before the world ended, a friend and I bought six Scepter cans off a guy. Included in that purchase were two holders that were, shall we say, extremely over built. Each one weighed in at over 20 pounds, for comparison the single holder that I already had weighs only 9 pounds! After having them sitting in my garage for a few months, I finally thought I'd do something with them. Now, I am no fabricator; I'm just a guy with an angle grinder, reciprocating saw, a 110v Craftsman Mig welder, and a free Sunday!
I wish I had thought to take a before picture, but basically each holder had a ton of unneeded metal on the sides. And this isn't light stuff, its 1/8th inch steel. By cutting them down to an "L" I shaved 10 pounds out of each holder! After hacking them up, I flipped the ol' buzz box on and did a really ugly job of welding them together (that's what flap wheels and paint's for, right?). Once they were solid, I pulled the old holder off the back of the Trooper and started the process of mounting the new one.
Since this setup is significantly taller than my old one, I had to drill holes into the top and bottom of door in addition to the old license plate holder holes I'd been using before. All told, I used ten mount points, connecting all of them with steel bars on the inside of the door for rigidity.
Once I'd drilled all the holes it was time to clean up the door panel, plug all the old excess holes, and paint it with some bed liner.
After everything had dried, I mounted it and loaded it up with two full cans. My biggest worry was if the door could handle the weight. But I've seen other Troopers out there with similar setups and honestly, that door is pretty stout. So far, everything seems sturdy and solid!
Aside from where the plate is mounted, I'm happy with how the "recycling" project turned out. I thought about mounting the plate down low, but I really didn't like how that looked. And if I have to if I have to open both sides, meh, no big deal.
#59 ·
hessmess said:
That looks nice, I assume that the holder is tight enough that the cans won't come out through the sides??
That's correct. The lip along the bottom and back is 2", and the arms hold them in super tight and they latch and lock. So they aren't going anywhere.
#62 ·
Nice set-up for the dual cans. I know when I installed my ladder on the door I ended up through bolting it from the interior section of the door with a spacer between the two sections so the weight wasn't only on the outer skin. Not sure if that how you did yours or not but if you run into any issue you could try that.
#63 ·
I built an inner frame so that it sandwiches the door panel between that and the can holder. Did a trip with two loaded cans last month and took a bit of an jump, unintentionally, held up great!
