Hi Everyone,
The other day I was driving to work and went to roll my window down. Pushed the button and the window went down a few inches then I heard a scraping noise and it rolled itself back up. Since then pushing the button had the opposite effect as it did originally and the window would only go up and down a few inches.
I then used the window a few times over the next few days since I didn't have time to take it apart. Of course it stopped working altogether.
Took the door panel off today and here is where the questions will start
I see two cables inside the door and a big pulley that they attach to. Both cables are reasonably intact. The motor is strong. I see at least one hole that the cable can go in on the pulley.
Pretty sure I can get it working again but the bracket that holds the top cable is bent. I need to be able to get to it.
Does anyone know if the door on a 96 rodeo disasembles any more than just taking the interior panel off? Will I need to remove the entire apparatus to get to the upper bracket that hold the cable?
Anyone who's done this before, tips?
Thanks,
Nathan
Thanks,
Nathan
