OK... I have just about had it with this one. What is the trick to loosening the power steering pump pivot bolt on a '94 3.2L Trooper? I know it's a 14mm bolt but the bolt head is so close to the houseing of the pump that I can not get the open or closed end wrench around it, and the holes in the pulley are not close enough to the bolt to allow me to get a socket on the bolt firmly enough to turn it. I've attacked this thing from the top, the bottom, the wheel well (where I still could not get the open ended wrench around it) and I've finally come to you guys.
What's the deal here? I know I'm not that bad of a mechanic, having done oil changes, tranny swaps, head replacements, sender replacements and all that fun stuff that takes twisting and bending and scrapped knucles, but this is rediculous!
Thanks for your help!
-Carl
-Carl
