Well hello again.....
Here is my continuing saga, I have a rebuilt (S&S Engines SUCK!) 89 2.6L 4EZ1 Motor that is spuddering under loads around 3K RPM. Dont bother mentioning exhaust problems. (the exhaust & CAT is completely new) When going up a hill or on the highway up an incline the whole truck will "buck" a few times, revs stayhigh but thats probably from the tranny pulling them up.... If you apply more fuel i.e. mash the pedal, the buck will become a more frequent and the noise is hard to explain.....Its like the motor is misfiring and not producing power to the wheels.. if you are thinking cluth slippage, this is not the problem, the clutch and t/o bearing is new too..!? Winter is comming and I am trying to figure this out and help would be good help.! The entire drive line is OK too along with the rear. I dont think its the distributor, could the coil be on its way out? I am not sure how the coils in these things act when they get a few miles on em.... lets say 120,00 miles on em.. (this is when others with bad coils should chime in) can a bad coil produce problem intermittantly under load?
