Hi,
I have been trying to find the correct pinion seal part number for the 12 bolt rear axle for my 92 amigo. Does anyone know the correct number for this part, keep getting the 10 bolt pinion seal even though part is listed for the 12 bolt. Has anyone found a part that can be ordered through car quest that will actually fit?
Thanks in advance
That bites....looks like www.rockauto.com has both 10 bolt and 12 bolt seals along with part numbers and dimensions if that would help. Other then that, after reading complaints about this and that aftermarket belt and or seal, I'd probably buy it from JLemond.
yeah I had ordered one from rock auto, they even list the seal dimensions which I had measured and they matched, but they still sent the wrong part. I was very frustrated to say the least.
smm12,
"SEAL; OIL, FINAL PINION", 4EZ1, P/N 8-94408-084-1 Should be correct for all rear 12 bolts, Amigo's, Trooper's, PU's, through at least '94.
As mentioned above, JLEMOND should have it.
Hope this helps,
GB
