Cheapest lift is a set of coil spring spacers for the rear. You can get a set of Daystar 2.5" spacers for about $80. Crank the front t-bars to level height. Add some 285s and your done.latintrooper said:dude. i have a trooper like yours, what do i need to do to lift it without spending a lot of money. i just want to lift it about 2"
i think the most you get from cranking the t bars is 2 inches.ebacherville said:if you did the 2.5" ones could you crank the torsion bars up that far in front to match the rear height?
Thanks,
Jason
Yes, rear has 4" of lift, so I'd say frnt is cranked at least 3". I still have a couple of inches of downtravel.ebacherville said:if you did the 2.5" ones could you crank the torsion bars up that far in front to match the rear height?
Thanks,
Jason
