1 - 4 of 4 Posts
I have a 2.8TDi Vauxhall Frontera that is running with Isuzu axles with an Aussie Locker up front and an LSD in the rear. I have recently after much searching found an open 12 bolt diff off a 94 plate Big Horn so I can now fit my rear Aussie Locker.
While rebuilding the diff I managed to shear off 1 of the crownwheel to diff carrier bolts and would like to replace all 12 bolts on the crownwheel. After talking to my local Isuzu dealer for them to order the bolts I either need a part no for the bolts or a chassis no for a Trooper with and open diff so they can find the part no and then order the bolts :roll:
Is there anyone on her that can help :?:
Have you tried here? http://www.myisuzuparts.com/
U.S. models though the parts might be the same. Site includes illustrations, parts names and numbers.
How awesome is that, found the part no, hopefully its the same as in the UK :D :D
Many thanks for your help :D :D
Most welcome. Parts numbers change now and then though dealers, etc can normally cross reference them. Good luck.
1 - 4 of 4 Posts
