1 - 19 of 19 Posts
The one in the back is the coolant temperature sensor. The one off to the right I'm not sure.
-Robert
AlexXx said:
I thought the part to the left thats broken is the temp sensor...the one on the back had a hard line coming from it and the post had two post coming off of it which had two hoses. I can't remember what the lines ran to through. I gotta dig up another pic.
Yea that one is the temp sensor. From my perspective it looked like it was behind the other one lol
-Robert
AlexXx said:
No prob rob. I meant the threaded hole in the back. I looked through my manuals, but I can't pin point it.
The threaded hole could possibly be for an EGR tube, but I'm not familiar with the Isuzu Z motors.
-Robert
That threaded hole is right underneath the throttle body, right?
-Robert
I'm pretty sure it's an EGR tube, but again I'm not familiar with the 2.8's (which is not an Isuzu Z motor, but a GM TBI motor lol)
-Robert
if some one doesn't answer by AM I'll go take a look at mine and get back to you All of my emission stuff and such things are intact DAVE
The THRD hole is for your vac hose to the power brakes DAVE
I double checked that is the vacuum port for the power brakes.There is a steel line with a fitting that bends around the TBI then turns to a rubber hose to the brake booster. There is a hose that goes to the charcoal canister from the thermal valve (black post thingy in picture) This is on a 1989 2.8 V6 that is all original as far as I can tell, it is also the same on a 1991 that I did the 3.4 conversion on. DAVE
Try jlemond he is the Isuzu guru on parts He is here on the Planet give him a PM and he can probably help you. Other option is 1- Find one at a junk yard 2- Find a fitting for that thread and make your own just be sure to use a regular OEM hose to the booster so it has the check valve DAVE
1 - 19 of 19 Posts
