P1275 is accelerator pedal position sensor
P1225 is a fault in the electronic throttle control system
P1125 is throttle position/ accelerator pedal communication error
Basically, it sounds like you either have a failed throttle position actuator or accelerator pedal position sensor... could also be a short in the wiring. Note that the 2000-2002 Troopers have drive by wire throttle control rather than a cable.
