No, you are not, you are on here to make money, Buster is not. And yes, it was babble.What you fail to see is we are on the same team.
There are two separate +5 Vdc supplies, some sensors share one supply and a different set of sensors share the other supply. The issue to resolve is why only the IAT sensor is affected.No short, replacing the PCM will fix the problem;
If shorted, replacing the PCM won’t fix the problem.
That’s my understanding, right?
12mV could mean a broken connection, far more likely than a short to bat +.Let me double check! If it’s .12v , what does it mean? But I remember first digit is 1 , it’s impossible to be .12.
Thank you for your input!12mV could mean a broken connection, far more likely than a short to bat +.
