Isuzu trooper 2000 3.5 L
I have replaced so many iat sensor from web, none of them are working! I’m waiting for oem sensor from Japan.I have replaced the connector too, still no luck. I wonder it’s the wire problem? Which pins shall I use to install a new wire for iat connector? Also I measured the connector with ignition on , I got 12v instead of 5v , what’s wrong with these symptoms? Is it reference 5v grounded problem? Will installing a new wire and disconnecting original iat wire fix the problem ? Your help is appreciated!
