Id go with replacement rear coil springs, that way it will also improve the ride quality and not sag as much.
Coil spacers are used for additional lift of coil springs. So you can use them with your stock springs or replacement ones.
Personally I like how 3" lifts look. Not too high or low IMO. Just look around in the members ride section for some pics.
OME 913 = 2" Lift for full size Rodeo
OME 912 = 3" Lift for full size Rodeo
So in a Amigo just add about 1/2" - 1" on those numbers. If you're still not satisfied a 1" coil spacer kit will only run you about $40.
The hood latch should have a metal bracket that mounts through the plastic panel in the dash. Two screw is all that holds it.
After you lift the rear end with new springs, or spacers, or both... you crank the tosion bars up front to match.
Which cost absolutely nothing. Just adjust the 27mm bolt on each side of the frame.
