only drives in winter mode
157 Views 1 Reply 2 Participants Last post by  Buster28
my 02' rodeo 3.2 4*4 only drives in winter mode. then at 25 wm kicks off and i can go on my merry way. if i slow below 25 i then have to dead stop and put wm back on. i have reverse also. wtf is wrong? p1870. i hate the thought of getting rid of it but........ help me keep my rodeo rollin!
1 - 2 of 2 Posts
To produce the 1st gear ratio in L (Manual 1st gear), the reaction drum is held stationary by the brake band, this causes the reaction drum sun gear to also be held stationary.
When the planetary gear set input sun gear is rotated using torque supplied by the Torque Converter the planetary gear set carrier and attached tail shaft "walk around" the stationary reaction drum sun gear producing the 1st gear ratio. To produce the 2nd gear ratio, the 2nd clutch is applied and the reaction drum brake band remains applied. In 3rd gear and 4th gear (“Overdrive”) and Reverse the reaction drum brake band is released.
Therefore, if the truck will move backwards in Reverse, but L (Manual 1st gear) feels like you’re in Neutral and Winter Mode (3rd gear) produces forward motion the reaction drum brake band is either not applied or is worn out and is slipping. If the transmission has a lot of miles on it the reaction drum brake band is probably worn out.
The bad news is you have to disassemble the complete transmission to replace the brake band. However, sometimes you can get a few more miles out of the brake band by adjusting it as shown in the video:
1 - 2 of 2 Posts
