Hello,
Over a year ago the idler pulley seized on my 98 Rodeo 2.2 sending the cam belt out through the timing cover and crashing the valves.
I've swapped in a recon head and got the engine more or less running, but have failed a few times to get it through the smog test. It ran quite well for the first 25 miles (when I was readying the ODBII for the smog test) but then CEL came on as I arrived at the test station (cylinder 3 misfire). I changed plugs and wires and tried again, but the next time engine had a very slight misfire on way to test station and then would not idle smoothly to hold the 15mph test. The test was abandoned.
Since then I've only done a few laps of the block and misfire has got worse. The car idles pretty nicely at 800rpm on the driveway, but then bucks like crazy as I accelerate up into 2nd gear. You can almost drive through it by putting foot to floor.
The CEL light stays off (apart from when I disconnect sensors - so I also suppose the PCM is OK)
I've also checked following:
I get about 21 inches of vacuum at idle
I've not found any vacuum leaks using a hose, spraying soapy water etc
I can hear all the injectors ticking away.
Compression is 145-155 across the 4 cylinders
MAP, IAT, O2, TP, VSS, ECT sensors seems to work OK (I have a USB scan tool that charts the data - great value for about $40 & I've also followed Haynes checks)
Timing marks seem to line up OK (as close as I can get anyway, without going a whole extra tooth out)
Also I have changed the plugs, wires, air and fuel filters.
Then I have following deviations / queries from the Haynes manual.
1: : Idle speed stays constant when I disconnect the IAC valve (though both IAC coils seem intact and pintle definitely moves under PCM control)
2: The coil pack connection order seems to be 1432 (not 1342 as shown in the Haynes Manual)
3: I can't find anywhere what the connection is at the back of engine, right next to the coil pack (like a copper nail head, with a female spade connector that slips over it). It was disconnected for a while. Now reconnected
4: I think I have a linear EGR, so can't check this.
5: I don't have PCV, Thermac or AIR system?
Also have noticed the following:
6: manifold vacuum erratically drops to almost atmospheric when engine is bucking (both on MAP chart from scan tool and also a vacuum gage that I set up in the cab)
https://lh5.googleusercontent.com/-B1y_ ... 2520PM.jpg
(Left side of chart is idle, then a short test drive, right side is engine stopped)
7: my inductive timing light reads 2X the revs when hooked to wire 1. Also the flash is a little erratic.
I've been chasing the Smog test problem around and around since the beginning of the year (I only get to 'touch' the car every few weeks, or so)
It would be great if anyone can confirm 1-5..
On 6 & 7 I'm curious if a fuel issue (say fuel blockage at the injectors) could cause ignition to be erratic. Or is the irregular timing light flash a sure sign something is wrong with the coil etc?
I've not been able to figure out how I can even test the injectors?
Or anything else (even if it's advice to give up and scrap the car)
Many thanks in advance, if anyone can help.
Pete
Pete
