Well I dropped off a driveshaft to be retubed at a driveline specialist. He told me that sitting at stock height, I would be fine. But If I were to lift it later, I would have to get it retubed to a longer length. This all makes sense, but is it something I will have to do right away after lifting, or at all? I plan on a 3" with extended shackles and add-a-leafs.
Also, I will be eliminating the carrier bearing, and angle grinding that lower crossmember. Will this crossmember need to be reinforced up top following this?
