Point â€" Counterpoint:
Rodeoholic said:
im going manual. most of the time at uwharrie, i was in neutral just rolling. i only put it in gear going uphill. i did that to try to save my on the way out clutch. even if i had an auto i probably would have done the same…
I completely understand the desire to save the clutch, but putting that part aside for a moment, and concentrating solely on the idea of ‘coasting’ the downhill sections…
Under normal operating conditions, I’m inclined to advise against it. (No pun intended!) --- There's a whole lot to be said for engine compression braking, especially with Tera Lows… if for no other reason than the fact that it saves your brakes, keeping them a lot cooler, for when you really need them.
BEFORE my Teras, I would very often be in 1st Gear and 4-Low on a steep downhill section, and still riding the brakes to stay off the tail of the rig in front of me â€" but if I’d been coasting it, the
ONLY thing keeping me off of their bumper would have been the brakes â€" and in many situations, particularly while going down the back side of a rock or ledge, coasting it would have also raised the potential for tire slippage on the break-over - however, with the driveline engaged, the slippage is considerably less pronounced (if present at all)...
With a manual, keeping it in gear (whenever possible) = More Control.
AFTER the Teras, I could run those very same trails in 2nd Gear and 4-Low, and hardly ever have to get on the brakes at all. --- But on the few occasions when I’ve needed to go slower (whenever it was
really steep), I’ve simply down-shifted it to 1st and crept my way on along.
* I have yet to encounter a downhill section - while idling along in 1st Gear and 4-Low, with someone behind me with an Automatic - where the driver back there didn’t come on the CB and ask me to pick up the pace (`cause they just couldn’t go that slowly) â€" Not even Andre’s Passport (Auto + Teras) can creep as slowly as mine (Manual + Teras) on a downhill grade.
Manual + 4-Low + downhill engine compression = SLOW (+ Tear Lows = EVEN SLOWER)…
Compared apples to apples; the Manual is capable of going slower on a downhill grade than the Auto,
every time.
bigpoppax2 said:
My first trip to Uwharrie with the 88 I was getting pissed at how slow people were going in front of me because I couldn't keep it in gear and in 4wheel low. I was on the clutch constantly just to keep it running.
The Teralows helped this some, but not completely.
You weren’t behind me, were you?
Seriously, I’d have to say that some other factor must have been involved as well, because in 1st Gear and 4-Low, with the 285/75/16s and 4.56 gears on your old Trooper - compared to the 265/75/16s and 4.30 gears on my Rodeo - your crawl ratio should have been almost exactly the same as mine. (*Shrug*)
At any rate, it’s good to know that you’re pleased with the set-up that you have now.
Rodeoholic said:
…i think this is mostly driver preferance.
*Ding-ding-ding!*
Give that man a cigar!
Cheers!
Smiley
