All these wacked-out, oil-analyzing, long-drain interval, synthetic polymer, razzle-frazzle guys crack me up.
We spend 60 bucks for a tank of gas every week.
Those oil-heads literally keep themselves up at night deciding whether to go 20,000 or 15,000 miles on an oil change (which cost them like a half-tank of gas) On top of that they send off their damn oil to be analyzed. Hello guys, you are driving a car, not a locomotive that takes 200 gallons of pricey oil.
Change the damn oil every 3 or 5k miles, use what the hundreds of Isuzu engineers determined is the best viscosity, and be done with it.
OK, maybe if you need to make your bearings last 500,000 miles, go ahead with your oil-obsessed lives.
You really gonna keep that car that long? You think the car is gonna keep you that long?
Lastly, go around to your neighbors. Find the guy with the most miles on his car (mine has 243,000) and ask about his oil changing obsessions. 9 times outta 10 they just stop on over at Jiffy Lube ever 3 months and be done with it.
Costs me (us) less than a tank of gas.
99% of people will get by fine, doing exactly what you have said- to not worry about it and just change it... the rest of us(~1%) are just finding interest in an area that most people don't give a $%^& about. we'll have our fun trying to get 500,000 miles out of the car, we all gotta have interests and hobbies, lol... The fact that we are spending 60 bucks for a tank of gas, is all the more reason for us, to find an oil. at any price, that works really well for our particular engine... it's a small price to pay compared to the overall operating cost.
Fact 1. No matter dino. synthetic. silicone, or some sort of secreat GOD
made lube. They will all squeeze out at the SAME pressure and leave
your bearings dry. Viscosity being the same of course. I am not talking
slickness here.
this isn't entirely true.. we talk about "film" strength of oils... the film strength is how much pressure is required to push the oil out from between 2 surfaces. Generally speaking, the film strength of any modern motor oil is above and beyond any situation a normal engine should encounter... but, for the record.. most dino oils "pressout" at around 500PSI, whereas a good synthetic holds up to around 3000PSI. A significant difference- but a difference that doesn't make a big difference for most engines.
Fact 3. Because these solids additives screw up emissions by coating
sensors and catalist new oils are actually getting WORSE. They are
requiring less be put it. Thus more damage can happen during high
load operations.
true- for some oils.
Fact 4. Heat affects viscosity more on dinos and cheep synthetics than
does High quality synthetics (Royal purple, Red line, ....). Red line
for example has very few viscosity improvers because it simply does not
need them. It also has very limited detergent additives.
if an oil, whether dino or synthetic, is rated 10W30... they will both be within the range of viscosity specified for a 10W30 accross the measuerd temps. Different oil manufactures choose different actual viscosities within the range allowed... (you might hear someone talk about a "thin 30, or a thick 30"... oils at opposite ends of the range for a 30 weight). A better way to state what you are saying- is to say, that the synthetic oil, stays thinner at lower temps(better flow) than it's dino counterparts, and suffers from less breakdown and shearing when exposed to very high tempuratres.
There seems to be a very large misconception about the way oil viscosity and tempurature corrilate... the number in front of the W is NOT defining the oil weight when cold... It should not be looked at the same way the latter number is looked at. The "W" rating.... mereley says that the oil falls within a particular viscosity at low temps. the LOWER the number, the thinner the oil is... however.. oil is ALWAYS much thicker at low temps, than it is at high temps. Oil thickness.. is measured in Centistokes- a measure of kinetic viscosity, (bigger numbers=thicker)... the following chart is the specifications for Mobil Delvac 1
Mobil Delvac 1 5W-40
SAE Grade 5W-40
Viscosity, ASTM D 445
cSt @ 40ºC 102
cSt @ 100ºC 14.8
Viscosity Index, ASTM D 2270 151
Sulfated Ash, wt%, ASTM D 874 1.35
Total Base #, mg KOH/g, ASTM D 2896 12
Pour Point, ºC, ASTM D 97 -45
Flash Point, ºC, ASTM D 92 226
Density @ 15ºC kg/l, ASTM D 4052 0.854
As you can see... at 40 degrees celcius, the kinetic viscosity is 102 cST, that drops dramatically to 14.8 at 100C(close to operating temp of oils in most engines). When you get down into the below freezing range, most oils register a few thousand cST. Go cold enough, and the oil is so thick, it won't pump or poor... A good wide range synthetic, is usable down into the -40 to -50 degree range.
This is also why I believe that oil additives that contain solid lubes like
moly are needed. Why they are hard to find I have no idea. Liquid
additives should be avoided at all costs.
Havoline dino, and redline synthetics, contain ample amounts of moly. Both are great oils. If you want to beef up the moly content of any oil... "Valvoline Synthetic Oil Treatment" (VSOT) is an addative in a little silver bottle that contains a large amount of moly, a good complement to any low-moly oil.
you guys have to be careful when picking a very large range oil, like a 5w 40. The reason that oil has such a range is because there are extra polymers added to it. Although the polymers help to get the extra range, after a while they will shear from the heat and pressure and become a hinderance. So if you guys dont need the large range then don't get it.
"Mobil is offering a "no-risk performance warranty" to fleet operators using Delvac 1 in new engines, such as the Cummins N14, Caterpillar 3406, Detroit Diesel Series 60 or Mack E7. To qualify, the truck or tractor must log at least 100,000 miles a year with under 30 percent idling time. Its engine maintenance and fuel economy (at least 6.5 mpg) must be documented. Mobil's EM/PA II Oil Analysis Program must be used. Advance written approval from Mobil must be obtained for oil drain intervals beyond 60,000 miles and/or four times the OEM recommendation"
This stuff is pushing 60K+ miles per oil change in over the road trucks- and Mobil is providing a warrenty for lubrication related failure for these truckers- I doubt this particular wide range oil, is having any problems with it's add-pack not holding up.
Speaking of wide range oils.... the idea that these oils may not hold up well due to their VI improvers, is really being shot down latally... There are a large number of Used Oil Analysis's posted over on BITOG from users of 0w30, 0w40, and even 5w50 synthetic oils.. some people have gotten their best UOAs on these oils, there is no sign that these oils don't hold up as well as the more classic 10W-30.
