When I had my 1st Trooper the 4 wheel discs were pretty impressive performers in 1988. I did some tweaks on them and found a sweet set of pads that is long since out of production. I used to commute to the nutcase capital of Wash DC. The brakes got tested pretty often. I could lock up all 4 32x11.50 BFG's if I needed to. That's a lot of footprint to lock. Almost a square foot of contact patch at each corner.
Fast forward to these days. When I built Red Beans I wasn't yet aware of the big brake swap. So I built it with Powerstop drilled and slotted rotors on all 4 corners and EBC green stuff 6000 pads in front and Wagner thermo quiet ceramics in the rear. I wasn't blown away by the braking. Just didn't seem to be what I remembered. The EBC's needed to be HOT to stop well and the ceramics on those rotors felt greased. So last year I did a big brake swap on the front with semi-mettalic pads and stock 2nd gen rotors. I turned the rear Powerstop rotors and added semi metallic pads there as well. It was an instant difference. Much better! And they stopped well cold also. These days I drive pretty gently normally and leave lots of following distance and have yet to really test the brakes in a panic situation.
Well today I went fishing. 1st time I've had the boat wet since August. She was a little light as the 17 gal fuel tank was near dry.I wanted to run the fuel out before winterizing the boat. I've not weighed the boat. But I figure the load is near but under 2,000lbs. I do not have trailer brakes. Surge brakes were illegal in MD till last year and electric brakes and muddy water don't mix well. This is the rig.
So On the way home shortly after dark. I was coming down a slight downgrade on a 2 lane highway about 45 MPH. I see a big doe run across in front of the car in front of me. Me and the passender both said "ok where are the others" There are always more than one. we looked and didn't see any. Then " Oh S***!" :shock: This med sized doe darts out in front of me. RIGHT NOW and HERE. I had slowed a little. I nailed the brakes HARD. NO problem at all locking all 4 32x11.50 BFGs quite easily on dry pavement with the boat on the hitch. I did the human ABS. Lock, lift, lock, lift. I brought the rig to a quick short stop in the road. The deer was doing the same thing. Braking and skidding. When we stopped if the doe had lowered it head it would have been resting it's chin on the hood of my truck right behind the passenger headlight! It's chest was maybe 4" from my front bumper corner and fender. It looked at me and I at it and it turned and ran back in the woods. WHEW!
I was very impressed with both the brakes and how the whole rig handled. The brakes stopped very short and hard. The modulation and control was great. The trailer didn't even think about getting untidy nor did the Trooper. Both stopped straight as an arrow.
I'll probably be adding surge brakes to the trailer in the spring. I've been thinking about it for a while. But it's nice to know I can throw some serious WHOA on this rig without them.
