1 - 14 of 14 Posts
OK, my 2001 Honda Passport with 16" stock wheels needs new rubber.
First off, truck has no lift now. I will be putting trooper springs in the back for a 1" lift and cranking the t-bars in the front.
Second, I am looking to go with 265/70 16's
This is per the thread stickied up top. Backspacing confuses the hell out of me. How do i know what the backspacing on my stock wheels are?
Will these tires fit given my application?
If I googled it right it's a little over 30inches so it will fit with a cracked TBar for sure and should fit as is with little or no rubbing. I doubt you'll really know unless you tried. I had 30s on my rodeo when it was totally stock forever. Backspacing confuses me too I just go by negative or positive offset.
P.S. the trooper spring will probably give you 2 inches of lift in the rear.
Backspace- measure from the inside wheel rim to the wheel mounting surface. Every Isuzu rim I have measured has 3.75".
You tire selection will fit & work best on a 7" or wider rim, if yours are narrower consider a 245/75/16- same diameter, just a bit narrower.
Newer gen Isuzus have quite a bit more backspacing than older ones. Based on the way my aftermarket 3.75" backspacing wheels stick out on the 93 Trooper, the stock wheels were probably around 4.5" backspacing.
Yep, my stock 03 Rodeo wheels are about a 5.5" backspacing.
I'm not sure what your passports backspacing is, but you should be able to fit that size tire with a small lift no problem. Also like one of the guys above me said, Trooper springs will give you closer to a 2" lift if they are in good shape.
So now it comes down to:
265/70r 16
or
265/75r 16
Do you guys think I can get away with the wider tire?
I went with 265/70/16 Firestone Destinations LE.
Couple things:
- I put trooper coils in the back and t-bar cranked the front
- Without that there is NO way these are fitting on stock suspension. Even with the lift I am going to be trimming the front mud flaps where they slightly catch.
1 - 14 of 14 Posts
