1 - 7 of 7 Posts
I have a 91 amigo and I have no pressure on my clutch after I replaced the clutch master cylinder. I need help on why I can’t get clutch to build pressure no matter how much I pump it.
They're a PIA to bleed. Two things you can try: Figure out a way to compress the slave cylinder and bleed through slave bleeder. OR I used a turkey injector, small weedeater fuel hose and I reverse bled mine by "injecting" the fluid through the slave bleeder and forcing the fluid (and air bubbles) up and out of the clutch master cylinder. Vacuum bleeders didn't work. Pressure bleeder didn't work. Dennis
1 - 7 of 7 Posts
