Howdy. Common problem for the plastic gaskets at the lower intake to go bad on the 3.2. These are torqued at 18 ft lbs if I remember correctly. Overtightening these will crack them in a heartbeat.
Idle the engine and spray some brake clean or carb cleaner around the lower intake. Be careful and have a fire extinguisher handy. This should find any vacuum leak you have. Also check around the throttle body assembly.
If you just did the lower gaskets, it's real easy to knock off a vacuum hose on the right side of the throttle body assembly where all the EVAP hoses are. Also, on the lower gaskets.... Did you use silicone? This is a place silicone should not be used.
Check for bad plugs and wires. Also, take a stethoscope and listen to your individual fuel injectors. They should all create a clicking noise. Or better yet, check live data with a scan tool, or check for injector pulse at the end of each injector wire. Is it hard to start in the morning?
See my post about the EGR passageway too.
Hope this helps. Good luck.
-Wrench
