1 - 12 of 12 Posts
Discussion Starter · #1 · (Edited by Moderator)
Hi guys, new member here. Picked up an 86 trooper a few months back and was slowly fixing bushings and motor leaks when the engine tossed a rod. I'm in the process of swapping in a 13bt Toyota engine and auto trans, along with doing a sas with the Cruiser axles as well.. will be selling some trooper specific stuff here shortly from the c223t engine and drivetrain. Along with front ifs suspension components. Thanks for looking!
Thanks guys, hoping to make a pretty good pace on this project. 4wd is all new to me, so I'm learning as i go.. mostly been building rwd drag cars for years until now.
Here is a rear bumper I was working on when the motor let go. It's about done. Just needs a hitch receiver tube and plate to the chassis, and some pulling lugs cut and welded on.
Rear spring mounts are tacked on the frame, and I fabricated a pair of front hangers last night to try out. I'm noticing my springs are a few inches shorter then the rear trooper springs people seem to use a lot.
giusedtobe said:
Man I am always impressed at you guys with the fab skills. Wish I had them :cry:
Buy cheap welder
YouTube
Simple as that, mostly.
Enemigo said:
Buy cheap welder
YouTube
Lol I have actually thought about just that. One of these days. Still building a bumper that fits and looks good is no hack job.
That's what I did, but I haven't built that much yet. I hear you on the bumpers. Everything so far has seemed amazing in my head, then less so once it gets built.
I build a ton of **** that just doesn't work out haha.. you just have to try stuff until you like it at first. Eventually you get more of a fabrication sense for what's going to look good and function properly.. having welders at home saves me tons of time. This is the first project im actually not working on at home right now. I will take it home when it's closer to the plumbing and wiring portion of the project. But fabrication type stuff im going to be doing at work since the equipment here speeds up the process tremendously.
1 - 12 of 12 Posts
