1 - 14 of 14 Posts
· Registered
Hey Guys
my Girl has a 1999 Amego 6 cyl with 68K miles and last week the dreaded check engine light came on.. the ideal will not hold steady when she's cold (ie it jumps a bit ) and now when she tries to place the truck in gear (automatic) the truck stalls -
I plan to ask the folks at Autozone to trobleshoot the problem with their OBD
any ideas what could be causeing this?
Thanks
Steve
· Registered
Thanks 2eyefishclaw,
well we went and the car had seven codes the guy reccomened that we change the spark plugs (got five done the last one by the brakes seems to be a real pia)
well it runs smoother BUT it still stalls when she is warm after driving a while (just after start-up)
sorry but i don't understand what you mean by a simple EGR problem
Thanks again for all your help!
Best
Bass
· Registered
Bass- make sure you have either NGK or denso spark plugs in there. Like 2eye says, could be the EGR valve is stuck open, dumping too much exhaust into the intake at idle. Could also be a bad intake manifold gasket as well- this is VERY common with 1998+ 3.2/3.5's.
G/luck!
Joel
· Registered
yup we used NGK plugs
any idea where i can locate the EGR value?? and is it pretty simple to change? ok a little more reading and i beleive i have to remove the air filter tube that goes to the intake and clean the intake with some carb cleaner.. does this sound right? I am going to buy a shop manual tonight
Thanks again!!
· Registered
As for the stalling when putting it into gear. I used to have a 78 Chevy custom that did that and it turned out to be too much tranny fluid. Simple enough but it confused the hell outta me for the longest time. :oops:
Cris
· Registered
Bass, the EGR valve is at the rear left-hand corner of the intake manifold. It's cylindrical shaped can (soleniod valve) about 1.5" in diameter & 2-3" long. You unplug it, unbolt it & pull it up & out of it's mount that's cast into the intake manifold. You'll see a 3/8" stainless steel tube that runs from the left hand exhaust manifold to the EGR base. Thats the feed tube. The EGR port inside the intake is several inches insite the intake, behind the throttle plate.
G/luck
Joel
1 - 14 of 14 Posts
