1 - 6 of 6 Posts
Because this mismatched situation is sad:
I assume there are no reproductions so looking for used.
Thanks, Shawn. I believe you have a $50 minimum, correct? I was hoping to spend a lot less than that, but I may need some additional odds and ends as well.
Shawn, what are you doing to sell just hardware "fixes" for these triangle vent windows?
From what i've seen, they are riveted into the frame you can see underneath the rubber molding that goes around the bracket. That's why I've been selling the entire frame window bracket and all.
What am I missing here?
To install this part you will to drill or chisel off the rivet head. To install the replacement window part you simply need to install new pop rivets.
Still looking to purchase the one missing piece reasonably cheaply. Otherwise, going to attempt to fab something up.
Dan
1 - 6 of 6 Posts
