1 - 2 of 2 Posts
Alrighty heres the deal, i need to know the width of the stock trooper wheels. I am planning on taking the 33x10.50r15 swampers on my ford and swapping the tires so the trooper will have the swampers and the ford will have the 30s. So what width is the trooper rim (15x6"?) and will it fit a 33x10.50? Thanks.
Premium Member
The stock tires that came with 235 75R15 tires was 15x6. This also had a narrow offset. I'm going to suggest that some 15x7 neutral offset wheels will be a better match for both the width of the tire (for tread wear) and for the stance of the vehicle. 15x6 will probably work just fine, but I haven't tested it, so I can't say for sure what will rub. With the 15x7 (either factory Isuzu or some cheap steel rockcrawlers) the tires will just rub the frame up front on full lock, and because the frame is smooth there, no damage will be done.
-Tad
1 - 2 of 2 Posts
