1 - 6 of 6 Posts
Anyone have a good set of rear calipers they'd like to part with?
Also could use a known good set of coil packs(shorter #6).
This truck has taken a back seat to the old priorities list, so I need something on the cheap end of things :mrgreen:
Thanks,
Jim
Hey, as a fellow 2000 Isuzu tropper owner I'd like to give you an advice. At one point I mixed up my coils and so whatever was on the 6th cylinder was lost. I tried with all my might to identify the "shorter" coil but it was a no go. I did buy this truck used and it's possible that perhaps the previous owner replaced the coil pack and thus there is no short coil on the engine but it is also possible that, that is not the case since the original plugs were in there. I would just get the 6th shorter coil pack brand new from a store to ensure it is the correct length. It's not worth the headache associated with measuring and comparing coil packs and making sure it's the right one.
Thanks for the heads up Medic.
I'm pretty sure the number 6 coil is marked differently than the other 5. Check the numbers on the side. At least on my truck they are.
would you mind telling me what the markings are? for #6 and none #6? thanks.
The #6 is marked '9L03', and the others are '9L11'.
I shall look tomorrow! thanks for the help btw.
1 - 6 of 6 Posts
