1 - 1 of 1 Posts
Top part of the motor sounds like it's ticking very loudly, checked the bottom of the motor and the side of the crank case with the screw driver, doesn't sound like a rod at all. But it comes from the top (Passenger) side of the vehicle. I figured it was just sticky valve(s) or lifter(s) and decided to run a bunch of additives to quiet it down. Still making the sound, so I put my head by the injectors and they are SUPER loud...
All of that ticking is coming from the injectors. Is that normal for the injectors to be so noisy? Or is there something I need to replace? Any info would help.
Also. My MAF sensor is going bad, I need to replace that too. But the motor runs fine, she has PLENTY of power and torque, runs smooth-ish (Slight misfire, but then again, she does have over 200,000 miles)
1 - 1 of 1 Posts
