i put mine to the right of my spare. not super convenient since the can hides the rear hatch handle. but, if you loosen the ratchet strap, makes it easy enough to access the handle. plus, i think it looks great there (not many other options).
i removed the plastic on the rear door, drilled 4 holes, and some hex bolts and washers to secure it in place.
5 gallons of gas is approx. 30 lbs. not sure the washers will spread the weight evenly, thus preventing extra damage to the body. but, so far I have only used the can to move 2.5 gal. should be fine, even if full
ok cool I was debating on putting it there or mounting it on the inside of my truck I just wanted some ideas, is it easy to remove tail gate plastic?
yeah, pops right off. just be gentle!
thank you very much! I cant wait till it gets here so i can mount it up.
