1995 trooper 4x4 with a 3.5l drivetrain and manual transmission
Hey all, I've searched for hrs online trying to see if there was anything to put me in the right direction. That said, my issue is while driving I will get a random jerk every so often. I can be just slowly driving through town and it will happen, or it can happen on the highway. There are some codes set in the computer.
P0342 camshaft position sensor A circuit Low: I have checked the wiring at the plug itself and they have 5 volts at both the blue and yellow/red wire. So wiring seems fine, I cannot get the sensor out without taking off the intake manifold from what I've read. I don't have time to get into all that right now, but if necessary I will. From what I read, the ECM only uses it to start the car?
P0134 02 Sensor Circuit No Activity Detected Bank 1 sensor 1
P1133 Bank 1 Sensor 1 insufficient switching:
I checked the plug wires on the 02 sensors as well and all seems ok, I know I need to replace those, but I've cars in the past with bad 02 sensors and they never make the car run bad or cause it to jerk.
I checked all the plugs and gapped them if needed.
I checked the fuel injectors to see if one wasn't firing or acting weird, and all seem ok.
If anyone has any thoughts I'd like to hear them and discuss them. Much appreciated!
Here are some pictures of the live data
