1 - 2 of 2 Posts
Howdy all!
I seek a schematic diagram for my 1990 Isuzu PU, 2WD, 2.3L, "J" series PU. The LF turnsignal has ceased & my Chilton's only tells me half what i need to know :cry: ...where can i find one without spending a bazillion dollhairs?
Enjoy!
hi,
i can get those for you. I have the Helms 1990 Amigo/Pup manual. Onething you should try, the hazard switch on the top of the column gets all dirty, try moving it back and forth a few times fast to "clean" the contacts and see if your hazards work also. Common problem with the Pups and if neither turn light (left side front and rear) dont work, that could be your turn lever has worn out or is dirty. I have extra turn levers is you need the assmebly, but try cleaning yours first and i can email you PDF formatted wiring diagrams from the book.
good luck and let me know how it goes
Regards
Ron
[email protected]
1 - 2 of 2 Posts
