Hi all,
Three years later, I'm finally getting around to uploading and sharing my fuel pump access photos. After dropping the tank TWICE!! to fix what I thought was a bad fuel pump (turns out the pump was fine.), I said heck with this; never going to do it again (drop the tank). I think it came out pretty good.
Got lucky in my measuring (the ol' measure five times cut once) and hit dead center for the hole. Carefully using my dremel with cutoff wheels resulted in a very small cut line. Little too much pressure while drilling out the first spot weld, so resorted to our old stand by steel reinforced jb weld to fix it. The fuel pump photos are kind of random, just to show the OEM pump compared to the dinky aftermarket pump which I did not use. As the final touch, I prepped, primed and re-painted the floor with the leftover paint I had mixed from when I replaced the windshield gasket. Used stainless sheet metal screws to reattach the panel, with a white silicone to seal the small gaps. If I or anyone else in the future has to deal with the pump, it's easy access.
If anyone is interested here is the flickr link:
Trooper Fuel Pump Access
Jay
Jay
