One question: Where do I find the minimum thickness data stamped on the disc? I look everywhere and couldn't find anything that looked like a measurement stamped on the disc.
Everything went perfectly, perfectly that is until I had to remove those confounded (3) 4mm x 8mm flathead philips screws holding the lock washer onto the spindle nut!
Just like every guide says, the screws stripped no matter how carefully and gently I tried to remove them.
Eventually I resorted to carefully drilling off their heads, then pulling off the washer and unscrewing the exposed shafts from the spindle nut.
Once I got that out of the way and removed the hub, I was very dissapointed to find impact marks and some bending of the hub lip surrounding the hub grease seal. So this is what I paid the dealer to do for me huh? Fortunately, there was no evidence of grease leaking from the old seal so I felt it was okay to re-use the disc.
