I have the headliner pulled down and everything off to add the map lights and multimeter, problem is I don't have the harness for the multimeter pre-wired and the unit I bout did not come with the harness anyone have any ideas how to make a harness?
Otter, the only way to do it without the harness is to either cut of the plastic shield around the plug on the multimeter itself and connect the wires via the prongs on the plug or cut the plug off and work with the very short length of wires behind it. Maybe go onto a website the only deals with making plugs? There has to be something out there and hopefully score a plug out there.Otter said:I have the headliner pulled down and everything off to add the map lights and multimeter, problem is I don't have the harness for the multimeter pre-wired and the unit I bout did not come with the harness anyone have any ideas how to make a harness?
