1 - 4 of 4 Posts
Is it do-able? If so, anyone know of a source for a good quality power antennae? Did a planet search, but no results. Thanks!
Jay,
The term "power antenna" can refer to a device to amplify the signal or a
motorized device that can be controlled to raise or retract the antenna. The
former may be found from such firms as "Crutchfield", the latter may be
found from say "Amazon", ranging from $14.00 to $60.00. Can't vouch for
long term functionality of these units, but might be fun trying them out!
You could try the JY for a unit from a Caddy or Chrysler, assuming they
don't have antennas built into the windshield.
If going for a motorized unit, be sure there is sufficient room in the
under fender area to accommodate the girth and length of the unit.
Hope this helps,
GB :)
Okay then. Thank you once again for the excellent info. I changed the topic heading.
gb89amigo said:
Jay,
Hope this helps,
GB :)
My 89 actually came with an automatic antenna, but it was broken off at the fender when i got it. But they are out there, and even came stock. i would suggest asking jlemond.
1 - 4 of 4 Posts
