1 - 7 of 7 Posts
i just installed a limited slip in my 89 trooper and im not sure if its normal for it to shatter while turning.
when i start a turn with power on it chatters in the rear, if i do it without my foot on the gas it doesn't. Is this normal?
how much additive did you put in the gear oil? shudder is common when you don't mix in enough.
i didnt know you have to put additive in it. What is suppost to go in there and how much, i just put 75 90 gear oil in
the additive at the autoparts house is what I use. It sits right next to the gear oil. Follow the directions on the bottle for mixing.
thanks alot, i will do just that
the additive kinda helped, still not the best, ill look into the LSD fluid
1 - 7 of 7 Posts
