Well, I bought that Rodeo I posted about earlier. 113,000 miles, for $2900. Runs good, plenty of power, and the trans seems smooth. It has a constant slight tap, sounds like the lifter problem. In a few weeks we will be doing the t belt, tensioner, and water pump.
When I bought it two days ago, it was low on oil. I put about 2 quarts in it, and it was back on the stick. I am going to get the oil changed tommorow. I am going to take it somewhere, because our garage doesn't have heat yet (But that will be done Monday! :-> ). I plan to put some seafoam in it, then do the 5 minute drive to the place to change the oil. Does that sound OK? What kinda of oil should I have them put in? I was thinking of 0w-30...
My main question is oil pressure. The gauge is weird. Sometimes its like around 15 while sitting at a stop sign, sometimes its as low as 5, and close to zero. As soon as you give it gas, it jumps up to about 30, and will sometimes go a little higher. Seems to run just fine, could prolly use a tune up. Is this safe, or am I just a paranoid new parent? This thing has a 3 month 3,000 mile warranty, so if its gonna go I want it to go in that time frame.
