Just put a lift on my 98 stock rodeo, so I would be able to take it off road. I used daystar KC09103 1 inch coil spring spacers (35 each), and pulled some 99 trooper coil springs (20 a pair) they are about an inch longer than the stock rodeos, and firmer. with this lift, you also need longer shocks, i bought explorer pro comp ES3000 shock absorbers (about 80 a pair) with the back raised, you then just crank up the torsion bar for the front lift ( I used 10 full turns)
I also went from 265 70 16 tires (30inch) to 265 75 16 (31inch)
the result is about three inches of lift, and an extremely comfortable ride. I am excited to see how it performs off road!
my stock rodeo:
Lifted:
what photo storeage are you using 8) recon
